 Posté le: 25/06/2011 17:28:05    Sujet du message: lumiere verte du neutre reste toujours allumée |
Je viens de regarder dans le workshop manual du F650GS monocylindre qui possède le même moteur que le F650ST monocylindre
  Dans ce cas, il y a le fil du neutre proche du boitier du filtre à huile et il est possible que tu l'as coincé en réinstallant le tout.
  Dans la procédure de la page 00.17 il est indiqué ceci >
  • Remove the left-hand screw (3) securing the oilfilter cover (1). • Remove the cable for the neutral indicating switch from its guide. • Engage the oil drain guide, BMW No. 11 7 511, on the pins (arrows) on the engine block. • Position a drip tray beneath the engine. • Remove the screws (2) and remove the oil-filter cover. • Remove the filter element. • Fully drain the oil and clean the oil-filter housing. e Caution: Dispose of the used oil and oil filter in an environmentally compatible manner. • Fit a new filter element onto the oil-filter cover. • Coat the O-ring of the new filter element lightly with oil. • Check the O-ring of the oil-filter cover for damage and replace if necessary. • Install the oil-filter cover complete with filter element. • Installation is the reverse of the removal procedure: pay particular attention to the following. |
